Two machinists that I work with have come back to me with parasolid issues.
The first time, a machinist showed me a missing face on one of the parasolids i sent him. The model was perfect on my end. Even when I loaded the extracted parasolid into a new part file. The machinist was able to work around the issue by assuming both sides of the part were symmetric, but what if they were not?! This could have caused a huge problem down the line if it was not caught in time.
The second time was with our in-house machinist using MasterCAM he showed me jagged edges and what looked like gaps between faces on a parasolid I sent to him. Again, the parasolid looked perfectly fine on my end. Also, again, the machinist was able to work around the issue, but in a tedious time consuming fashion.
Also, I have seen edges that should be circular arcs, represented as splines, which causes issues in mastercam.
I have noticed that changing the facet settings from a default value of 1.0 to 20 or 50 greatly improves the graphical representation, but by doing this am I hiding defects?
If i generate a parasolid with a facet refinement factor of 1.0 or 0.5 will i get a lesser quality parasolid than one generated at 20 or 50 refinement factor?
To investigate the issue, we tried exporting step 203 and IGES models which turned out to be worse than the parasolids.
How can i expect a high level of precision from machinists when I dont even know what I am sending them!
Why does a parasolid look perfect in NX and like garbage in MasterCAM?
At the very least, I need to know what the workarounds are. I am using NX 10
