distance between view nx4
ideasuser
Industrial
CA
Hi
After changing 1 block size in the assembly, I have to do update sheet in drafting then drag all the views which lay on top of the other view out. I have 50 parts in my assembly and 50 base views plus many projected views and section views. Is there any way to set constant distance between views then they will move by themself. Thanks
First I have to ask, are you saying that you're documenting all 50 components of your assembly on the same drawing sheet? WHY? That approach went out with the Tee-Squares and Triangles.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS PLM Software
Cypress, CA
Thanks for your reply, yes, many tool and die designer still have all the blocks layout in one sheet.
just for plotting. It is easier to have many blocks layout in one sheet and plot it out full scale for tool die maker to hang it in the shop.
