Dear all
I'd like to have your opinion/experience on Materials for Sour Service.
I've been involved during a recent project in Dissimilar Welding beetwen Carbon Steel and Nickel Alloy (Alloy 625, Alloy 825) in a Sour Service environment.
As per NACE MR 0175 /ISO 15156 there are no particular constrains to apply this solution, but just the usual requiremtns in terms of hardness and so on.
Looking on the internet for technical paper i've found many author stating that a similar solution in Sour Service can be subject to SSC even if all the requirement of NACE /ISO are fully satisfied, due to a hard phase forming during the welding process.
Due the risk associated with a leak/failure of pressure containtment in Sour Service with high H2S conc. i think that even a remote possibility of failure should not be tolerated.
I think that NACE / ISO have a lack beacuse it doesn't metion this possibility of failure.
What are your idea/opinion on this matter?
ref:
- The catastrophic failure of a high pressure hydrogen vessel was the result of a combination of a. dissimilar metal weld that produced a highly susceptible ...
- Corrosion of dissimilar steel joints - a cracking tale (Bulletin - September-October 1999) on TWI Website
Vict
Corrosion & Materials Engineer
ref:
Vict
