Bayram2014
Geotechnical
Hi Everyone,
I am trying to reproduce the experimental results of a friction rig.
I have two plates (modelled here as 3d solids) one above the other.
After applying a normal (vertical) pressure (step 1) I start pushing the plate one at the top until the first sliding occurs (step2).
Then in step3, I stop pushing and wait for the fracture to propagate.
I am making implicit dynamic analysis.
I am using the exponential decay friction model in abaqus.
I have been playing with the friction parameters to obtain results comparable to our experimental ones.
With
FRICTION, EXPONENTIAL DECAY
μs, μk, dc
I noticed that with bigger dc, the slipping speed is higher.
I start to decrease dc to have physical speeds. However, when I got the dc value to have
a reasonable fracture propagation speed for the first increment, the propagation mode changes: In fact after a continuous
propagation of the slipping zone, I start to see disconnected small surfaces slipping, sticking or open.
We have not yet observed this phenomena experimentally.
A picture attached here shows the discontinuous zones of stick/slip.
Thank you for any help.
Bayram
With
μs, μk, dc
Bayram
