Hi, (Apologies this is my first post)
When moving my part part into the drafting stage some lines disappear.
It doesn't happen immediately but after manipulating some of the views using view dependent edits (on a section view and details of that view) the subsequent update of the sheet will cause some of the lines to disappear from the draft (no pattern in which lines go). From this point onward the lines are effectively 'deleted', they are not hidden by the view dependent edit or any show/hide feature.
The parent base view still has the missing lines, and any new section view has them as well. The issue appears to be triggered by one of details (not always the same one) and only affects the draft as far back as the section view. The update link between the parent and section view appears to be intact, however the parent is on a different sheet in the draft.
Any idea what is causing this or how to avoid it? I've been talking it over with the other NX users in the office and none of us can understand it.
Any help would be greatly appreciated as I've no doubt if i start the draft again (for the fifth time
) it'll just happen again.
![[sad] [sad] [sad]](/data/assets/smilies/sad.gif)
