disappearing icons 1
troy06
53
Whenever I restart my computer,all of the icons in Wildfire 2.0 and 3.0 that I have placed or removed return to the default icons.WHAT AM I DOING WRONG????
The customize screen settings file config.win stores all your customized icons and any flyouts or menu locations. This file which can be saved from the customize screen window is read when ProE starts just as your saved or company config.pro file.
If you did save your screen settings to a different name icons.win for example, ProE won't read it when starting up but you can open it from the customize screen window.
You may have saved it in one of your working directories, so search for any *.win.* in your working directories and then copy that config.win to your start directory.
Michael
