Direction through KWA
LWolf
Automotive
SE
why doesn't this statement yield the x-component of the direction vector?...
direction(Line.2)->GetAttributeReal("X")​
I have constructed Line.2 in XY plane, with 45deg to x-axis. A "Measure Item" of the line reveals the correct unit vector components (.707, .707, 0)
However, when I try the GetAttributeReal of the Direction command, I get(0,0,1) as components (for respective direction)...
Moreover, when I try to see what Real Attributes that are supported [direction(Line.2).ListAttributeNames("Real",false)] I don't see those, instead I see RatioX, RatioY and RatioZ, which seem odd, least to say...
regards,
LWolf
anybody?...
regards,
LWolf
direction(line.2)->Vector().Get(1,1)
Eric N.
thx for replying, itsmyjob. Cannot find the Vector() method... any ideas why?
regards,
LWolf
well, I'm on R30...KWA, KWE (not sure what else could be added as a shareable...)
regards,
LWolf
ok i have the same result in V5...last solution I could think of is: from the line you create 2 points and get the vector from the 2 points, normalize it then you'll have the value you're looking for.
Eric N.
thx Eric, the math is not a problem[lipstick2]. It is just that I'd like to understand what is happening... or why I don't get to do the Vector method, or what/why I get 0,0,1 as a result?...
regards,
LWolf
you can open an SR if you want to know about XRatio = 0, but you can also post on the community from DS maybe someone from R&D will check it.
The Vector thing might be because you're in V5, the code I gave you is from 3DX.
Eric N.
