rapid1348
- Jan 18, 2004
- 17
What is a good engineering practice to avoid direct contact between a stainless steel pipe with stub end connection and carbon steel lap joint flange ? Will painting the lap joint flange suffice?
My second question :To bolt up two stainless steel flanges with CS stud bolts and nuts ,what is the good practice to avoid the direct contact between the nuts and flange back side.
RezaMani
RezaMani
