Green 123
Aerospace
- Feb 19, 2024
- 63
How can I test a diode while it is still in a circuit without removing it completely from the circuit?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Yes all diodes are connected to the connector of GCU, so do you mean that disassembly of GCU is not needed for testing diodes?Please refrain from multiple posting
Is that a connector to the right of the diodes? At least 4 of the diodes appear to be connected to the connector, if that's what it is.
No, I simply meant that disconnecting the connector would isolate a large number of the diodes.Yes all diodes are connected to the connector of GCU, so do you mean that disassembly of GCU is not needed for testing diodes?
Ta muchlyYou have the ability to test the diodes through the connector. You can test two by probing pins 41 and 49 or 41 and 36. You can test one probing 41 to ground. 3 are testable between 41 and 13. One can be tested between 34 and 10. The diodes adjacent inv delay, PR, and UV will have to be tested on the board itself. This can be done if the board isn't potted. Most multimeters have a diode check function.
