Good day!
I do not work in engineering but i am a librarian with a new passion to terrariums.
I would need some advice for calculating the measurements for the sides of a flat top pyramid inside a rectangular terrarium.
Added is some screenshots of my 3D-model to show what im working with. The terrarium is 75x40x40cm and the square at the bottom of the pyramid will be 15x15cm or 20x20cm.
So what im doing is im building a 2 level aquarium/terrarium. Bottom level will be filled with water and the levels divided by a "flat top pyramid" shape made out of plexiglass/polycarbon sheet 3mm thick.
Because the pyramid is upside down and i need some sort of structural integrity for it to be stable i decided to level it (will have a pump inside it too).
My problem and question is. What is the method/formula to get outside measurements of the four separate pyramid walls? "The terrarium is 75x40x40cm and the square at the bottom of the pyramid will be 15x15cm or 20x20cm."
Might be something obvious im just not realizing but i tried to search online for information but english isnt my first language and im not sure what terms to use for finding my answer.
So this is why i figured an engineering forum might be my best chance!
Thank you in advance!
