Dimensioning to hidden line
wingman70
7
Is there a way in a drawing to dimension to a hidden line without having to create a section view. I am trying to show the depth of a pocket in a standard view showing hidden lines, but it will not let me smart dim to a hidden line.
You will probably be informed that it is not standard practice to do that, but;
Tools > Options > System Options > Display/Selection-->Selection of hidden edges-->Allow selection of wireframe and HLV modes
[cheers]
Jeff, that option is for retrieving entities which have been hidden.
Help files said:
Select hidden entities. When selected, you can select hidden (removed) tangent edges and edges that you have hidden manually when you pass the pointer over hidden edges.
[cheers]
[banghead]
Do not answer posts before coffee.
Jeff Mirisola, CSWP
Certified DriveWorks AE
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Actually, there is a type of view you can use for this as still be legal with the standards.
Select your view first. Then goto pulldown Insert>Drawing View>Break-out section. Draw in an enclosed spline around the area you wish to break-out, and OK.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
