In the sketcher task environment, when I want to dimension a sketch entity to a datum plane, if there is another sketch line "on top of" that datum plane, that sketch line is automatically selected instead of the datum plane. The only way to dimension to the datum plane is via the quick pick dialog or by manually setting the selection filter.
Is there a way to set a "selection priority" in sketcher to datums? That would save a lot of hassle.
NX8 Win7 i7-3770K@4.3Ghz 16GB Quadro2000
