SwinnyGG
- Jan 22, 2016
- 2,581
chez311 said:Thats very clearly not what I said. Not even remotely.
I agree, you didn't say that- but that's the conclusion one reaches if your line of thinking is followed to the end.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
that added subphrase serves only to aid in the ability of a Y14 compliant manufacturer to alter their processes as necessary without blowback from an engineer or designer
I do not believe it was intended to create a fundamental shift in the way drawings are created or interpreted
chez311 said:you said a nominal value tells manufacturing "where we want the center of the statistical distribution of feature sizes to land" and I said no, its up to manufacturing/quality to determine their own targets/process limits as long as its within the drawing spec limits. Maybe we have been talking past each other somewhat, but thats all I said from the beginning.
That nominal value tells manufacturing what we think the ideal dimension is.
chez311 said:If the latter, thats often subjective and also not always the case
chez311 said:What I am saying is that they really should just be concerning themselves with getting the most parts within the tolerance zone - and that clause frees them to do exactly that.
chez311 said:They can use the stated nominal as a suggestion if they like, but without specific instruction to do so it just (potentially) makes their job harder.
If, as you seem to be saying, nominal values with symmetric bilateral tolerances make life more difficult
since 99% of time a machinist will try and target the middle of the tolerance zone, so providing this value means less math is necessary 99% of the time
chez311 said:a simple case being the engineer desires a fit at MMC but the company's internal standard/standard practice requires all models be at the median of the tolerance zone.
chez311 said:claimed several times that I've said something when I clearly didn't and/or cherrypicked my statements without context
At this point I don't believe this conversation is productive, either personally or for the thread.
