Dimension Problem
majora
Industrial
When I create a new part in ACAD I always dimension the part before I add in all my corner radiuses and never had any problem doing so. Today seems to be different because after I dimensioned the part, I added the radiuses and all the dimensions jumped off of the intersection points and went to where the radius ends. Can anyone help me fix this problem?
PS- I'm running 2006
The variable DIMASSOC would be 0 if you want to stop this behavior.
"Everybody is ignorant, only on different subjects." — Will Rogers
Didn't seem to work...
If you are trying to disassociate an already associated dimension, try the command "dimdisassociate". (there's a mouthful)
If you snap to INT it may still work. Or if may work if you snap to APPINT. Not END though...
