Dimension extension lines.... 1
jdt020471
42
Does anyone know how to change the dimension extension line offset so that they are closer to the view.
Thanks in advance
Jeff
Do you mean you want the gap between the dimension leader lines to be nearer the actual entity being dimensioned?
If so I beleive you need to change WITNESS_LINE_OFFSET in the DRAW SET-UP.
Hope this helps.
maybe only a drafter
but the best user at this company!
