Hello All!
I am a mechanical engineer, and i have a project, which requires to "implant" a digital pressure gauge in it. Standard gauges can not be used because of the size, and can not be protected. The gauge not need to be highly accurate (+/- 1% full scale 0-150 psi (0-10 bar)), but need to work from -40 to +150 deg F. I have tried to contact gauge manufacturers, but the quantity is too low for them to get involved. All the mechanical part of the gauge i can make it, only with the electronics will need some advise. I found pressure sensors for this temp. range, i need 3 or 3 1/2 digit,3/8 to 1/2 inch high character lcd modules, also how to drive it with the sensor's output (can be mA or mV). The unit is in a remote place, no power supply is available, so must use battery. If anybody can help with advice, schematics, links will be greatly appreciated.
Thanks in advance
Thanks in advance
