Mass is what ETABS is using for determining bldg mass and your seismic lateral load. Gravity is your dead load used for gravity design. Why would these be different you may ask yourself?
Well, for example partition is now a 15 psf live load but you also need to include 10 psf in your mass. So, if your floor was 50psf DL with a 15 PSF partition live+ 40 for classrooms (let's say) then DL=50, LL=55, and MASS=60.
Another example where you mass input may be different than gravity would be for including your exterior wall mass within the model. Let's say you have an exterior wall that is supported below, but runs by a raised slab with a slip connection. You would model a zero gravity line load for the exterior wall, but the mass would be the tributary wall height x its weight since that diaphragm will see that wall mass.
I hope this makes sense.
If you're having trouble setting your unbraced lengths in ETABS you really should talk to a more senior engineer. The members should have a parameter where you can set your own unbraced lengths like 0 feet for your purlins (since deck is there) and your bottom flange bracing for your moment frame beams will need to manually assigned.
Lastly, you may want to create just a model with your lateral elements only. I don't like how ETABS handles the gravity elements, especially for a composite floor system. Hand calc those beams or use Ramsteel. Then just include your gravity beam mass as a unit load per sqft across your floor to capture those masses.
Also, keep track of whether you have member self weight being included in the mass. Really double / triple check your calculated mass from etabs with a quick hand calc. You don't know how many times I have seen floor masses being double dipped, or frame beam and column masses not being included depending on how your model is set up.
contact CSI for your etabs questions unless your company didn't opt for that. It is really helpful to talk to their engineers about modeling tips etc..
