Differance between B31.1 and Sec. 8 1
StW44145
Industrial
Jul 15, 2008
1
I have a customer that wants B31.1 and a fabricator that is Sec. 8. On the surface they appear to be one and the same but I don't know.
Is there a real differance between these 2 codes and what are they?
Thank you,
StW
They are different. B31.1 is a Code pertaining to Power Piping, while ASME B&PV Code, Section VIII is applicable to unfired pressure vessels. You really need to review the Scope for Section VIII and B31.1.
The fabricator which holds a U Certificate of Authorization from the ASME may perform nonboiler external piping fabrication to B31.1. It may not perform ASME B31.1 boiler external pipe welding fabrication.
There are many differences between VIII-1 & B31.1:
-B31.1 is closer to B31.3 than VIII-1, as befits the component being designed and fabricated.
-Calculation equations are different (such as shells)
-Material allowable stresses are a bit different.
-Inspection requirements differ
to name a few.
StW...
What, exactly, is the scope of your cutomer's work..???
Is it piping...presure vessels....boilers or what ?
You state: "On the surface they appear to be one and the same but I don't know"
Have you actually reviewed these standards ?
-MJC
