Flamefront
Automotive
With the advent of electronic controls on Diesel injectors, is anyone working on multiple injections into a Wankel type engine to "chase" the rotor around its path, coming closer to a constant pressure expansion cycle? Seems like a possibility is opening up here. The kludge way of doing it would be with multiple injection events from a single direct injector - the theoretically optimium might come from multiple injectors placed around the housing...
Related topic: Did Rolls Royce ever have success with their Diesel Wankels? It appears that the high surface to volume ratio of Wankel combustion chambers, plus the long, sickle shaped chamber would cause problems for complete compression ignition. Anyone have any comments on how Wankels do as Diesels?
