Diesel Tank Leak Test Procedure.
mfadzil
20
Hi all,
Is there any standard procedures for diesel tank leak test?Can anyone give me the link?
Thank you.
It depends on the size of the tank;- for a home diesel srorage tank, simply fill it up to the brim and walk around it looking for leaks. It is different for a new, large diesel storage tank on a refinery plant. You would probably use a vacuum device to detect leaks. It's also different how to detect leaks in a diesel tank on a ship, in a middle of the ocean...
Perhaps you could be a bit more specific with your request.
cheers,
gr2vessels
Thanks.
I must prepare Leak Test Procedure for diesel skid tank. I don't know how to do the procedure. Is there any outline for preparing this document?
Pneumatic and hydrostatic test can be fine. The tank sizing is about 3000mm W x 4000mm L x 400mm H.
Thanks again.
Be very very careful with any pnuenmatic or vacuum testing the former could result in a burst tank and resultant injury to personel while the latter could end up with a collapsed tank. You are better to fill it with water a pressurise it to 1 - 2 psi.
Sometimes the tank is filled and the welds/seams dusted with a fine powder chalk to highlight any wetness/weepage.
