Diesel pump suggestion for Dam Sparge System
Vin_i
Morning Fellows,
Had some questions about pump selection for the environmental dam sparge system.
the pipe will be PN12.5, DN50, 400mm, HDPE (blue line)
Environment Dam Sparge System.
Total length: 364m of 50mm blue lined pipe PN12.5
x4 90deg elbows
x1 45deg elbow
x50 Tee pieces with 40mm take off
x50 Spray nozzles with a 6mm orifice
Suction Lift Height: BOD RL 3.50, TOD RL 9.10
Suction Length: 25m
Throttling Valve: 50mm butterfly valve calculates the valve being open 100%.
Would anyone suggest which diesel pump I can go with? TIA
RL?
TOD?
A pump which matches your flow and head requirement (which you don't specifiy....)
Looks to be a lot of nozzles for the size of pipe.
