Diesel fuel flow sensor
MackayMiner
Mining
Jun 28, 2007
I am trying to measure fuel consumed by a Bobcat mini excavator with 60 hp Kubota diesel. I just need to have an accurate total of gallons used. I'm assuming I will have to put a flow meter on the fuel line as well as on the return line.
Does anyone have any suggestions?
Double meters would double the margin of error. Is there a reason you can't install a locking gas cap and simply measure the amount of fuel placed in the tank?
I want to have a fairly fast and accurate measurement of the fuel used. Say run the machine for 5-15 minutes and measure the fuel used during that time. So just measuring the amount of fuel placed in the tank won't work.
Could you mount the tank inline with a force sensor to measure the weight of the tank before and after your 5-15 minute runs?
-Reidh
You could just replace the tank with a graduated cylinder, and run from that.
Mike Halloran
Pembroke Pines, FL, USA
