Diesel Engine Load Acceptance
McManaman
HK
Hi all,
Can anyone tell me where can I obtain the free information of the maximum load acceptance related to the brake mean effective pressure (BMEP) of the diesel engine? e.g. BS 5514...
Also when I get the value of BMEP, how can I know whether the engine can sustain since the load is calculated with kilowatts, not psi or kPa?
Thank you.
Are you looking at a high speed or medium speed set, and is it turbocharged? The type/matching of the turbocharger is the main criteria.
If you can tell me the exact engine I can give you a fairly accurate figure.
Taylorg:
Sorry for the insufficient information. The engine speed is 1500 rpm with turbocharger. What I want to know how can I calculate the max. load acceptance related to the BMEP.
Thank you very much!
