I'm desperately looking for some help with calculation of vertical deflection of cold formed stud wall as shown in the attached drawing.
The stud wall is sheathed with 1mm thickness of steel sheet attached to the vertical stud members.
The approximate self weight of the stud wall is 3.5kN/m. The span between the dead load support is 5783mm.
The stud wall has two large opening as shown in the drawing.
I attempted to calculate the vertical deflection as per the B5.4 from AISI S240, but there is no guidance there for stud wall sheathed with steel panel.
Can someone please me with this? I desperately need someone's help on this. I would greatly appreciate for your help.
Thank you
Thank you
