B
Beauregard
Guest
When I am creating diameter and/or radius dimensions it seems that the only angle the leader to the circle or radius is the original angle where I place the text ie. when I try to re-position the dimension somewhere else around the circle it only allows the original position further or closer to the circle or a position 180 degees out. Can any one suggest me how to override this problem so that I can position the dimension anywhere around the circle or arc.
Thanks in advance.
Thanks in advance.
