Diameter-Radius Dimension
  • Thread starter Thread starter Beauregard
  • Start date Start date
B
Beauregard
Guest
When I am creating diameter and/or radius dimensions it seems that the only angle the leader to the circle or radius is the original angle where I place the text ie. when I try to re-position the dimension somewhere else around the circle it only allows the original position further or closer to the circle or a position 180 degees out. Can any one suggest me how to override this problem so that I can position the dimension anywhere around the circle or arc.
Thanks in advance.
rad dim
Turn off your ORTHO (F8).
rad dim
Turn off your ORTHO (F8). Are yuo moving the dim using GRIPS?
Ozzy
Type ddim and highlight the "DIM" style you are using on the left side and click modify on the right side and click the "FIT" tab and go down to "Text Placement" and choose "...without a leader". This option will allow you to place the text where ever you want.
