Structures917
If I have a beam that is 150' long with diaphragms at 25'-0" O.C. and a uniform torsional load acting on the beam. The diaphragms are acting as torsional supports for the beam.
would I use DG9 to check a 25' Long beam with a uniform load? or would it be a combination of a concentrated load at the start of the span, from the previous "section" plus the uniform torsion?
I ran a RISA 3d model of a 25' long beam and got similar result for the shear stress and warping stress when using the DG9; however, when I ran a model in RISA with a 150' beam, braced 25'-0" the shear stress in the beam was significantly higher. Which i'm sure its because its not just (1) 25'long beam. How would I use DG9 for this condition?
