HI.
IM AN ELECTRICAL GUY WITH A MECHANICAL QUESTION.
IM BUILDING A EXCERSISER FOR DOGS
ITS BEING DESIGNED AFTER THE OLD HORSE WALKERS.
THE PROBLEM IS NOT ENOUGH TORQUE AT THE END OF A 12 FOOT ARM THAT ROTATES IN A CIRCLE.
IM USING A .75 HP MOTOR @1725 RPM {AC}
60/1 GEAR REDUCER
AND NEED AN RPM OF BETWEEN 8 TO 14 MAX
SO FAR I HAVE USED A 9 INCH AND A 2INCH PULLEY TO GET TO AN ACCEPTABLE RPM. HOWEVER I DONT HAVE ENOUGH TORQUE TO KEEP THE DOGS MOVING. EACH DOG IS ABOUT 60 LBS. NOW I DONT NEED ENOUGH TORQUE TO PULL THEM ALL AROUND THE CIRCLE BUT I FEEL THAT 30 TO 50 FT. LBS. WOULD DO THE TRICK. NOW I THINK THAT I CAN DEVELOPE MORE TORQUE BY USING A LARGER PULLEY ON THE MOTOR BUT I ALSO NEED TO KEEP THE FINAL DRIVE PULLEY AT AROUND 9 OR 10 INCHES. RIGHT NOW I HAVE IT SET UP IN THIS SEQUENSE .75 HP MOTOR W/ 2.00" PULLEY TO A 9.00" PULLEY THAT DRIVES THE INPUT SHAFT ON A 60/1 GEAR REDUCER THAT HAS THE OUTPUT SHAFT COUPLED TO THE FINAL ROTATING SHAFT.
SHOULD I USE A JACK SHAFT WITH MORE PULLEYS ?
SHOULD I USE 2 PULLEYS FOR FINAL DRIVE INSTED OF A RIGID COUPLING?
IM ASKING FOR ANY ADVICE TO HELP ME SOLVE THIS PROBLEM.
THANKS
9PLOTTS
60/1 GEAR REDUCER
THANKS
9PLOTTS
