Determining whether a particular climate requires air-entrained concrete per ACI 318-14
jochav52802
81
Hello All,
I've got an outdoor concrete project near Los Angeles, CA and am trying to determine if air-entrained concrete is required based on ACI 318-14.
I'd appreciate help with understanding how other Engineers typically determine if a particular climate qualifies for needing freeze protection. For instance, is there a particular climatic organization/website and climatic data that are typically used/recognized to make this determination?
Another related question is if the geotechnical report calls for a frost depth, (in my case, only 6"), is that sufficient reason to consider the area as being subject to freezing?
I'd appreciate any support you can provide, thank you!
I'd use it for improved workability... in these environs almost all concrete except for interior SOG stuff is air-entrained.
Thank you dik,
Our contractor selected the mix and has indicated that it has sufficient workability.
As far as the area with 6" of frost penetration... here we have 6' and most outside concrete is air-entrained. Best to talk to someone local... a concrete supplier would be a good choice.
I would normally take the geotechnical report mention of a "frost depth" as indicative of a need for air entrainment.
