Spaceballster
Hello there,
Does anyone know of a way to determine the volume of a hollow part/assembly?
The method I'm using now is very cumbersome:
1. Draw the hollow body as a part.
2. Make a new part, use part copy to insert the part and also check the box for construction bodies.
3. Surface copy all of the outside surfaces.
4. Place a small protrusion inside your surfaces.
5. Boolean unite with the created surfaces, you'll have to hide the part copy.
6. SE creates a solid body and you can find the volume in the physical properties.
Griffin
Griffin
