I have a aluminum plate that is 2mm thick, diam 1.5 inches. I am screwing it down with four 2-56 screws into another aluminum plate underneath. Between the two plates is a polystyrene plate, same diameter, 1mm thick. this compresses against several small lenses to keep them in place. I want to determine the pressure that the polystyrene will apply on the lenses. I guess this goes to how tight I tighten the screws, but how do I determine the force the screws apply and then the force the plate applies? Below is a quick diagram of the sandwhich.
|--- screw
||(| these lines are the top plate, polysty plate,
||(| lens, and bot. plate from left to
right
Thanks for the input
|--- screw
right
