determining joint efficiencies
cookdog
Chemical
Is there a simplified version or wording of UW-11, in ASME SECTION 8, Div. 1?
thanks
1) Double-Welded Butt Joint (Type 1)
E
1.1 Full RT --> 100%
1.2 Spot RT --> 85%
1.3 No RT --> 70%
2) Single-Welded Butt-Joint (Type 2)
(Backing Strip in place)
2.1 Full RT --> 90%
2.2 Spot RT --> 80%
2.3 No RT --> 65%
3) Single-Welded Butt-Joint (Type 3)
3.1 No RT --> 60%
Note, equivalent welds to item 1.1 above include Single-Welded Butt-Joint back chipped and welded from the inside;
those may have 100% joint efficiency.
Weld Categories A, B, C, D (UW-3)
A --> Longitudinal Seams
B --> Circumfrential Seams
C --> Terminal Weld end in a flange
D --> Attachments
Type of Radiography
RT-1 --> Full lenght, full radiography of a;; butt welds
(except >= NPS 10 or tn >= 1 1/8"
RT-2 --> Cat-A: Full Lenght
Cat-B: T-joints
RT-3 --> Spot Radiography (UW-52)
RT-4 --> Partial / No Radiography
Seamless Heads & Vessel Sections --> 100%
Piping SAW & Seamless --> 100% ERW --> 85%
Q: Is there a simplified....
A: No. The best summary I know of is in the Pressure Vessel Handbook, Megyesy, part I section 7, welding of pressure vessels. This goes into what they mean by "types" and "category" and levels of x-ray. Then charts and tables tell you joint efficiency for various combinations of the above.
Please don't take this the wrong way. I do not know you, your problem or your background. And I am new to this forum. I strongly recommend you talk to a specialist about this as there are many considerations to joint efficiency.
Hi
go to PVeng.com and download the spreadsheet which give the data available in Megyeseys book in softform.
Follow the advice of Isthill and look at the thread. You will get bad info. surfing around. Remember you must submitt calcs.to your AIA.
Hi cookdog (Chemical)
I agree with deanc (Specifier/Regul) ask the AIA.
Leonard Stephen Thill
Leonard@thill.biz
Very interesting thread.
thanx isthill & deanc
HI cookdog (Chemical)
Also, Nooter Fabricators, Inc Quick reference Guide ASME PRESSURE VESSEL CODE (SECTION VIII, DIV. 1. Has all Testing Notes & Reference Notes.
The software program was free.
Leonard@thill.biz
I would recommend to see Flow Chart Diagram in Appendix of ASME Section VIII Div 1. I have not felt any difficulty to determine joint efficiency since I that flow chart. I made a summarized excel spread sheet, but this is only for me because it is customized for my own use.
