ride5150
- Nov 16, 2018
- 8
Hi everyone, a friend of mine is taking down a masonry wall and asked if I could design the lintel required to support the 2nd floor-roof brick/floor joists above. I am a structural engineer, but my masonry experience is limited to larger buildings with reinforced CMU...vs single wythe brick home/residential applications.
His contractor wants to pocket one end of the beam parallel to the masonry wall to the "right" in the pictures shown below, and will build a masonry pier on the "left" (against the perpendicular wall). He will place a plate on the masonry pier with studs welded to the bottom and grout. Masonry pier will be reinforced and also tied to the perpendicular wall.
I'm trying to determine the connection on the parallel-pocket side, as well as axial capacity of the wall, as it is completely unreinforced/no horizontal ladders. Can I use msjc methods for "unreinforced walls" even though there isn't horizontal reinforcing? I want him to grout the ~3/4" gap between the two wythes, however I'm not sure how feasible it is to get grout into this small gap.
Connection wise, same plate with welded studs or rebar on the bottom side in one line that would go in the ~3/4" gap, placed when the grout is wet so it bonds.
Pictures:
A couple elevation views/sections describing what I want to do:
Can anyone offer feedback? Obviously designing the beam and masonry pier is cake, its the parallel wall and connection that I'm thinking over.
Thanks in advance!
Pictures:
Thanks in advance!
