manj1987
- Apr 12, 2011
- 16
I have a proposal in which I will have to verify and model couple of pressure vessels on PVElite. I am not sure exact why they want to remodel them. I have raised below clarification. Kindly comment if someone has done similar task:
1- Our scope is to verify existing pressure vessel as per latest UT report(thickness) and taking design and dimensional parameters from existing As-built drawings, calculation and data sheet. Client to
confirm.
2- Verification will be done against latest ASME code and with main objective is to know if de-rating the equipment is needed or not based on vessel thickness and nozzle reinforcement. Client to confirm.
3- Any further assessment as per fitness for service standard API 579 will not be part of scope.
4- Client to confirm that along with latest ASME, vessel need to be verified for latest client specification. Client to confirm
5- Client to provide As-built drawings, calculation and data sheet for every equipment. Client to confirm.
6- UT report(thickness report) will be provided by client. Client to confirm.
