Design table questions 2
difficultone
Industrial
Can someone explain to me the value or need for a derived design table. I don't get why it would be important or valuable to create a derived design table.
Why is $USER_NOTES needed in a design table? Is it just a way to manually create a column or row header and not screw up the design table when you manually type in notes?
Where do you find the 32 bit integer number for $COLOR? I don't see the number in the Appearance Property Manager under color.
The color numbers are in the slider windows.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
A decent example of when and why to use a derived configuration:
Imagine a configured model for many o-ring sizes. There are many configurations each with the nominal size of an o-ring. Each config has a derived config as well. The derived config is the "as installed" shape of the o-ring i.e. compressed.
Just an example.
-Dustin
Professional Engineer
Pretty good with SolidWorks
I prefer to open my Design Table as Edit Table In New Window but when I do this and try to add a $STATE by double clicking on a Feature it won't work and I get an error message. When I do the same thing with the built in Design Table, no problem. What do I need to do so that I can use Edit Table In New Window and not lose functionality?
How do I stop this behavior -> In the Design Table I type something like $PRP@Description and the spreadsheet thinks this is an e-mail address. How can I stop this annoying behavior?
Go to Tools > AutoCorrect > Auto Format As You Type and uncheck Internet and network paths with hyperlinks
Thanks CBL. That one had been annoying me.
Eric
