When calculating the uplift loads for overturn moment calculations (sect 5.12) it states that P should be calculated from Appendix F as opposed to the actual design pressure of the tank. If the tank is small however P calculated in F.4.1 can be incredibly high and distort the calculations somewhat as that pressure will never be met. Do you still use this calculation as the input for the uplift requirements or use the actual design pressure of the tank perhaps set by the Pressure Vacuum Valve whic is a more realistic design pressure?
