Greetings,
I would like to ask if anyone can share an example on how to design a two story x brace connection... I am specifically confused as to how to find the shear and moments at different parts of the gusset plates in order to check its limit states. My initial approach (with chevron braces) was to cut the connections at different planes and draw free body diagrams to get the internal forces at the gusset... however after reading the AISC 14th design example I cant seem to reproduce the results for the chevron brace connection and the statics part of the example is not very detailed so I cannot find my error.
What I was doing (for chevron braces.. I have not even tried two story x-braces which is what I actually need) is... Since the two braces have a concurrent point (point A) at d/2 of the beam I decomposed the forces in X and Y directions and add them at this point.. the resultant is the reaction to keep the connection in equilibrium.. as expected I am getting no moments only a vertical(when loads in the braces don't have equal magnitude) and horizontal reaction... After this I perform a horizontal cut right where the gusset meets the beam and using the reactions at point A I can find the shear force and moment at the gusset. After this I figure I need to perform a vertical cut on the connection in order to get the vertical shear on the gusset as well as the moment.. But here is where I simply cant reproduce the results; what I was doing is cutting the connection vertically in half... so that the forces acting on this half are the forces at point A and the external forces from one of the braces.
Thanks.
Thanks.
