I am to design a shear key for a steel column of a braced bay in a pipe rack. Since there is a significant amount of shear at column base which is difficult to be borne by anchor bolts ,shear key has been envisaged.
My problem is where ever i seen calculation for the design of a typical shear key element (rolled section or plates in + shape welded at the bottom the base plate )flexural stress of this element (shear key depth is 200mm + 25grout-10mm gap = 215mm)has been calculated .
My question is why we need to check the flexural stress of this element when there is no place for this element to bend (shear key will be filled with non-shrink grout)?
