Design of L & T shaped R.C column.
msachine
IN
hi i am msachine,
my project work is related to design of L & T shaped R.C column.will u help me for the design procedure for the same or method of design.
Concrete columns of L and T section are not normally covered in detail in codes of practice. You need to use fundamental principles of section analysis, strain equations etc. Specialised software is the easiest solution if you have access to it. There are many software solutions from various suppliers. One that I use comes from .
