harmsgundam
Hi all,
We have a project regarding retrofitting of communication towers wherein I'll add an aditional angle bar to an existing diagonal member which is an angle bar as well of the same size. So the resulting section is a double angle. Now regarding the spacers to be place along the length of this double angle, of course after computing the required spacing base on AISC, I am planning to connect the spacers to the double angle section by means of bolts. The question is how will I know the right size of spacer and bolt/s to apply (i.e. the dimension and thickness of the spacer and the diameter of bolt to use)?
Thanks in advance to those who can enlighten me on this matter.
