Hi everyone,
I've designed a test ring for the hydro test of a tube bundle using Aspen's Mechanical Component Design.
my question is why does it offer 2 thicknesses for the loose flange and which one should be used for fabrication?
I mean I can see " Nominal Flange Thickness" and " Calculated Flange Thickness" in the result report . what's the difference between these two? as far as I know there's no standard dimensions for this type of flanges.
this is an example of the results I've got:
Flange calculated thickness: t = (M*Y/SFO*B)**0.5 = 42.8 mm
Flange nominal thickness: tnom = 68 mm
