Deselecting Annotations in Journal
Bleinweb
Computer
Sep 21, 2008
3
Hello, new to the forums here.
I'm writing a journal function and it works on an annotation that I have selected in drafting mode. I would like to be able to deselect the annotation automatically at the end of the journal code. I cannot find this function for the life of me!
Is there anybody here familiar with Journal that knows how to do this?
-Ben
Sorry, I realized I may have been a little vague in my first post. Here's a slightly better explination.
1. User selects an Annotation on a draft.
2. User runs my Journal function
3. Journal function works, but Annotation is still highlighted.
This is a confusing behavior because normally when you perform an operation inside of NX, it will then deselct the object.
ex.
1. Select Annotation.
2. Right-Click and edit the Properties
3. Add Properties
4. Click OK. The Annotation is no longer highlighted.
I hope that clears up what I'm trying to do.
-Ben
Dang! I forgot to mention I'm using NX 5.0
-Ben
if you are calling the ui.GetUI for your selection
you can set the following:
Dim keepHighlighted As Boolean = False
Mark Benson
Aerodynamic Model Designer
To a Designer, the glass was right on CAD.
