Dependant Mirror and Rotate
  • Thread starter Thread starter silkyslim
  • Start date Start date
S
silkyslim
Guest
I cut an asymmetric pocket into a roll using Insert>Sweep>Cut.
I need to mirror this feature about the roll centerline, and also rotate it about the roll axis a few degrees to create the next pocket.
I accomplished this by choosing the swept cut feature and using mirror, to created a mirrored copy. Then I copy/paste specialed (applying rotation) the mirrored copy to create an independent moved copy. Then I deleted the mirrored copy.
How can I do this while still keeping the new pocket dependent on the original?
like this:
If I understand this correctly; then one way is to create the firct cut as a surface, copy surface, do the move-translate on this and then solidify the first surf and then the second. Your second feature will then be linked to the first.
Second option:
Just put relations to make all relavent dimensions of sweept cut equal.(like dxx=dyy).
One time you have to create two swept cuts.But after putting relations, if you edit one..another will update automatically.
