I agree with roncity. The asphalt producer (not necessarily the contractor) will have most likely run their own Rice density, on the material you tested, which will give you the exact number you're looking for. If you have a copy of the delivery ticket, the producer's phone number should be right on there. It should be fine for you just to call dispatch with the date and truck information. I used to do this on a daily basis, and they are always glad to track it down.
Good luck!
