As stated by others, you don't say what you mean by "muck", but if it is peat (organic content of 30%, or greater), watch out. Most organic soils are highly compressible, and exhibit secondary compression settlement behavior which can go on for over 20 years. Peaty soils are compressible even under relatively light loads. Placing permanent fill will make things even worse. These soils can be surcharged with a temporary fill embankment (with surcharge pressure equal to at least 1.5 times the permanent fill and structure footprint pressure)in 2 or 3 months, and then a monolithic slab/footing system used to allow for some long-term differential settlement. If excavation and replacement is not an option, consider short piles such as treated timber or helical piers--these will probably cost about $20/foot. The owner/developer should be made aware that these soils are highly compressible, difficult to predict settlement behavior, and could result in lawsuits down the road if the site is not prepared properly.
