Delta-Delta Ground Fault
karalahana
52
Hi, ?s delta-delta connection exposed to ground faults? ? figure it is not. ?f not how do we dedect these faults?
Ungrounded systems are a bad idea. That said, grounds may be detected on a floating system with voltage monitoring. Delta systems may be grounded with a zig-zag transformer or with a wye/delta transformer.
Bill
"Why not the best?"
Jimmy Carter
