A
amitk_001
Guest
I am working in Pro/E drawing module and recently I put some incorrect
geometric tolerances on dimensions. I clicked the Geometric Tolerance,
and selected the tolerance and placed it on a dimension. Now the
problem is I need to delete the tolerance. I cannot delete the
dimension, I can only erase it. But If I select the feature again and
select show dimension the tolerance shows up again. It also shows up in
the model file.
I found one way around it. It is to go in sketcher mode for that
feature and delete the dimension and create it again. That way you can
get rid of the tolerance.
Is there any other way?? I tried searching for Gtol through find feature, I found the Gtols but was not able to delete it.
Let me know if there is any other way to solve this issue
Thanks,
Amit
the model file.
Thanks,
Amit
