Looking for some help in regards to "product moisture load" in LBS/HR of moisture removal to size dehumidification equipment properly. We have pharmacuetical softgel capsules of 500mg each, of which we need to remove about 10% moisture from this product. This issue is that this 10 % water content removal is being done slowly over a 36 hour process in a drying room that recives 129 lbs. of this product each hour. (Thats 117,000 capsules produced each hour X 500mg each capsule converted to LBS, which gives us our 129LBS of product each hour).
The moisture load that we calculated from this info above is 12.9Lbs/hr "product moisture load in lbs/hr". (10% of our original 129lbs).If this sounds correct please let me know?
If so, how would we calculate the 12.9lbs/hour over the 36 hour drying process? Multiply 12.9Lbs/hr X 36 hours and just take the 10% of that number to be our "moisture load content" for the drying room?
We are not concerned with any other loads at this time, such as room loads, etc.
Just our product load.
Any help would be greatly appreciated.
