SKJ25POL
- Mar 4, 2011
- 358
I like to get some opinions on the correct degree of indeterminacy of below frame?
Thank you
Thank you
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
BA said:Changing the joint at top of right hand column to a pin, the sloping cable carries all of the horizontal force
Tomfh said:Some of the force is carried by bending of the rigid elements. You still can't solve the internal forces with statics.
BA said:I suggested making it determinate by changing a rigid joint at D to a pin. That makes it a determinate structure which can be solved
BA said:which is statically determinate
BA said:With a pin at Node D, the cable force is P(h2+L2)1/2/L; the axial force in columns AB and DE is P*h/L tension and compression respectively.
