Definition of North Elevation
KimBellingrath
103
Can someone tell me where I might find the exact definition of an elevation? Such as "Facing the side that faces south you are at the North Elevation".
I could use a document stating this.
I thought that was it but I need to quote a spec or document - do you know of one?
North is usually "project north", which may or may not be true north. "Project north" should be defined on the drawings. Always was on the HVAC plans I worked with.
This is starting to seem like defining what "is" is.
